Anyone any experience/knowledge of these light control products please?
jb Media light control
I've got it, and it works fine. You will need Intertechno's products (
I operate my lights with the jbmedia lightcontroller for 2 years now and it works fine. Never caused any problems.
Good product and good customer service.
I own the PRO version, too and I do like it much more because it allows somple and comortable, detailed configuration:
http://cms.jbmedia.de/index.php?option=com_content&task=view&id=95&Itemid=74
Thanks to all who've so far responded. Much appreciated.
๐
Any chance this will work in the USA?
Very goog product - buy !! I have it since 2 years and Iยดm happay with it !
@turbotool:
the Lightmanager PRO B&O version will work in the USA easily because it needs a simple USB power supply.
But I don't know about the RF frequencies if they are different in the USA!?
Regarding the Pro version, how is the IR reception compared to an LC2?
According to their info, a B&O IR receiver is included in this version
I can't compare it to a LC2 because I haven't a LC2 :-)
There are 2 versions of the Lighmanager Pro:
- Lightmanager Pro
- Lightmanager Pro Bang & Olufsen
The first version has an Ir receiver for Philips Pronto, Logitech Harmony etc. it wouldn't work with the B&O remotes!
In my opinion Ir reception is good. The Lighmanager Pro is lying under my Avant (left to the Avant feet, so you only see the dim blue led) and it receives the light signal from a Beo 4 that is mounted to the wall in about 2-3 meters away without any problems.
Register to access the forums, reference material, and exclusive member benefits โ including our monthly prize draw.
