Any of you have any experience with iTunes 10 and BM-Link?
I upgraded my iTunes and now I can't get any response from the BEOport on my peripheral items
I use a mac of course (BM-link)
MJM
MJM
Mine is fine - iTunes 10, PowerMac and BM-Link. Have you restarted the BM-Link?
several times!
i'll make another run at it when i get back home
thanks
MJM
some of us (there are 2 or 3 threads about this) found that iTunes 10 crashed immediately it was started until we deleted an iTunes plug-in that was either associated with our Beosound 2s or with BMLink
Did either of you get this crashing ? and did you remove the plug-in module ?
I'm with Elephant here. iTunes 10 would not start until those plug ins were removed.
After reading this thread and others, I'm still getting the message,
"The application iTunes quit unexpectedly. the problem may have been caused by the BeoSoundPlugin plug-in."
I have already deleted the plugin from my applications folder, and a search via Spotlight does not reveal any other files of that name. So I reckon I must be doing something really stupid for iTunes not to open?
Any tips greatly appreciated,
Rob.
Rob.
Nevermind! Found out that I still had to delete a 'BeoSoundPlugin bundle' from my library folder, so I'm up and running again.
Rob.
