Dear Gang,
I need some advice about setting up a new TV.
I’m getting a BV-7 55” (it’ll be a Mark II model with BL 7.6 speaker), and I wish to realize my long-held dream to utilize an Apple TV as the primary audio source and let a pair of BL3s ported through the Beosystem 3 be the primary speakers (i.e. I would use the BL 7.6 just for watching the TV). My goals are to have a paucity of equipment, to avoid buying a B&O “audio head” unit by using the BS3 in this capacity, and to utilize the DACs in the BS3 to smooth out the audio from the Apple TV.
I have three questions that plague me and any advice from my fellow beophiles would be much appreciated (even if you only know the answer to one question, I’ll take the advice):
- Can I connect a second generation Apple TV to the Beosystem 3 through both the digital optical out (for music) and also through the HDMI cable (for video)? Obviously, I wouldn’t want to use them both at the same time.
- When the TV is in the “standby” mode with the little B&O red dot showing, I desire to use the Beo 4 (type 1710) to turn on the BL3s without ever having the screen come on. I’m thinking that utilizing separate inputs on the BS3 for each of the two Apple TV outputs will help facilitate this (i.e. the optical input to the BS3 will be solely devoted to audio so that the BS3 sees the Apple TV as an audio master when this input is programmed in to the BS3). I’m also thinking that hitting the “AV-DVD” or the “AV-Aux.” button on the Beo 4 will allow the BL3 speakers to go in to “Speaker 2” mode so that the screen never comes on, and I therefore never have to use the “Picture Mute” button. Does this sort of set-up sound possible?
- Also, in this set-up, when using the audio-only portion, I’d use my iPhone or iPad as the remote and / or audio source. I’d therefore like to use some third party software to enable me to also use the “iOS” device as a remote for the B&O system. This would also afford me the ability to program “macros” in to the remote control software. Does anyone have any experience with ThinkFlood’s remote control software and hardware for iOS devices? Or, do you guys have a different brand of iOS remote to recommend?
Thank you in advance for any and all advice.
Mark D.
