Issue with AppleTV after upgrade to tvOS 13
ibg001 wrote:
Do you know how to activate the new control menu on the ATV where you can switch user and hibernate?
On the Apple remote it is a long press in the TV button. What is this on the BeoRemote if possible?
Anyone?
Yep. My BV11 MK1 works as it did, downloaded the ATV PUC update and now ATV turns on with TV.
As mentioned before, you need to reassign the new PUC in source in place of the old ATV PUC
How did you manage to get the new menu? Where you can switch users etc? Long press on the TV on the Apple Remote does this. But the new PUC dissent have this option?
No idea, only set up as single user? Will have a look.
Why update ATV. What do you get, besides trouble ?
In regards to what version Mr Pan?
Anyone else noticed that the "Apple Remote 4th gen from OS13" PUC for the Apple TV 4K has disappeared from the PUC database?
It's PIA because the Apple TV keeps on streaming even when I put my BV14 into standby... Apple TV refuses to go into stand-by. And yes... it's configured the right way un the PUC settings of the connection.
