Issue with AppleTV after upgrade to tvOS 13
After upgrade of my Apple TV HD to iOS 13 my BeoVision 8 will no longer turn on the Apple TV.
If I turn on my Apple TV with the Apple Remote then I can use BeoRemote One to navigate on the Apple TV. So it is not a cable issue. It only turn on and turn off that does not work.
Any ideas?
Try pressing the green button after selecting the AppleTV on your remote
It is not working.
There is also an issue with turning the Apple TV off after the TvOS upgrade. It turns off and then on again.
Since the atv is not very power hungry, I keep mine on all the time.
Same problem here.
Are the PUC codes still being updated?
Perhaps something is changed on Apple TV in connection with the new control Center window.
Just press “back” or “exit” twice.
Even multiple presses on the "back" button no longer always works. The green button must often be pressed. Something has definitely changed with the update.
I forwarded a bug report to B&O's BeoCare... Let's see what happens..
Karel.
It will probably not help to submit a support case to B&O due the fact that customer service could be better. If they even can understand the issue. 😀
