Issue with AppleTV after upgrade to tvOS 13
ibg001 wrote:
Do you know how to activate the new control menu on the ATV where you can switch user and hibernate?
On the Apple remote it is a long press in the TV button. What is this on the BeoRemote if possible?
If you have a BeoRemote One BT, you can pair it with your Apple TV 4/4K.
I have done it, and if I long press the Home button on the BeoRemote the new control menu is shown.
Please observe, that the volume control is not working in this setup.
Best regards
Dyssegaard
It is very simple (when you know how to...)
Just press the yellow button for a few seconds and the AirPlay menu will appear.
It will only bring up the Airplay menu - not the new control menu ...
Best regards
Dyssegaard
Oups! - that one....never missed it.
Seems that we need help from the guys, who wrote the new PUC.
Frederic wrote:
I have the same issue, ATV 4 turns back on. Why ? Tried everything (turninh HDMI- CEC off, airplay off, ,,,) something in the newer tvs must maybe sent over hdmi from time to time turning atv on. I put some heat sinks on it. D'ont care anymore
It turns on. So that’s a test that passes lol.
The light did go out on the ATV maybe a few mins or so later could have been 15. But it did eventually turn off
I was more if the control menu is available with the PUC setup. So no mapping for the long press for the button. B&o could easy have put this in the list menu on BeoRemote One where the AirPlay menu already is.
Just updated your PUC files from the (service) menu.
Or search for PUC: Apple Remote (4th Gen from OS13).
Hi Fl_ip
Can you find which button is mapped to the Apple TV button and long press that gives the new Control menu?
Hi Fl_ip
Hi Fl_ip
