Issue with AppleTV after upgrade to tvOS 13
Is there an upgraded puc for Beosystem 3 systems?
Did the update... works perfectly again.
Do you have a 4k box? Could that be the difference? I updated as well but nothing changed. Does switch off work?
The AppleTV is directly connected to my BV14. It's starting up and switching off correctly.
Karel.
Probably... but you'll have to contact your dealer as I don't have a BeoSystem3
Thank you very much for your feedback. Are you running ATV4 (4K) or NON 4K.Reto
Running tvOS13 on Apple TV 4K.
Karel.
I updated the PUC and reassigned it on my BeoSystem 4 and I'm still needing to press the green button to wake the Apple TV from sleep. I have 2 Apple TVs: the most recent non-4K Apple TV connected via an Atlona Matrix and a 4K Apple TV that connects the video directly to the TV with the sound extracted to go to the BeoSystem 4.
Does it make a difference what we select on the BeoSystem 4 for the power on/off setting? I'm using the "always on" setting for the Apple TV.
Again we see how bad the B&O customer service has become, which is sad.
The answer from B&O customer service is: "If it is an iOS that cause issue we recommend you to contact Apple Support."
Can it be worse? The so called customer service do not even know that there is a PUC update already and probably not even know that PUC tables is a part of the B&O software.
Now I just hope that the new PUC table can be installed manually by a technician since my TV is a BV8-40.
