Anyway I have submitted a case. #190930-000256
Issue with AppleTV after upgrade to tvOS 13
As TS mentioned, Apple has updated their OS to version 13.
My ATV4K didn't react either after the update. (connected to BS3 based BV9)
When I switch on the BV9 with the DVD (ATV) instruction, the screen stays blank. When I press Menu and then the green button, it also powers up the ATV. But pressing the "exit" button twice, gives the same reaction and works a bit faster. But nevertheless, it proves that not every update will be an improvement. The same happened with tvOS 12 where it killed the passthrough feature from the installed Kodi
My support case #190930-000406
Karel.
Indeed it is!
Sounds great, but: I downloaded the new OS13 Version. But same behaviour as with the 'old' version. Still to push the green button.
Anyone successfull?
‘downloaded’, yes - but did you also assign it to your box....instead of the old one?
The green button do nothing at all.
My setup is a BV8 40 so I cannot download a new PUC table. So one day I need get it updated by a B&o technician.
