Is Wireless 1 compatible with Beomaster 4500 and BeoLab 3000?
Hello!
Does anyone got experience with Wireless 1? Does it work well? Easy to install?
Will it work with older products?
I got Beosystem 4500 and BeoLab 3000.
1.Can I use wireless 1 and skip the cables between the beomaster and speakers?
2. out of curiosity, could I use wireless 1 and skip the cables between Beogram turntable and Beomaster or BeoLab?
I have put the speakers on one wall and I need to put the receiver and turntable on the other side of room
Cheers!
Hi Carl,
I'm using Wireless 1 in my home, and am relatively satisfied with it. I use it to connect my Beosound 9000 with a Beolab 2000 in an adjacent room (so I use Masterlink on both ends).
The transmitter and receiver units are in total about 8 m apart and separated by some wooden furniture and a door. Most of the times it just works and I can't complain, but now and again the music just stops and I have to turn the link speaker off and on again to make it work. It could be because of the relatively crowded 2.4 GHz Wifi band around where I live.
What surprised me is that there is no perceivable lag between the main room and the link room.
to answer your other questions:
1. yes, that's the idea. Provided your Beomaster has a Masterlink socket. I don't know if it has that.
2. I'm not sure that I completely understand what you mean. You can have several transmitters and receivers in one setup, but as far as I remember, the transmitters have to be spaced a certain distance apart. So I don't think that would work out for you. And remember: you need Masterlink.
Carl probably means the Transmitter 1 and not the Wireless 1.
Thanks for the reply!
my poor English is confusing, I'll try again :)
My second question :
can I use the transmitter and receiver for wireless communication between the Beograd turntable and the beomaster?
@Carl
No!
These are for transmitting of sound wirelessly - from a sending device to the speaker/s.
I have checked, Beomaster 4500 doesn't have Masterlink socket.  Does that rule out Wireless 1? Or do I have any options?
"Connections:
Speakers 2 sets
CD DIN
TP 1 DIN
AUX DIN
OH/TP2 DIN
link 2
Link compatibility:
Master Control Link"
I have found something called "BeoLink Converter", http://www.beoworld.org/prod_details.asp?pid=983
Will that do the trick?
