Hi all:
The MX4000 that I have finally started making regular use of (it was in storage for about a year) has just recently started emitting a electrical type smell that can roughly be compared to warm TCP. It is not very strong but is noticeable if you concentrate on it. It definitely is coming from the TV as if you move towards the back of it the smell is more obvious.
I am not overly concerned about it but the one that must be obeyed is convinced the TV is going to blow up or shock her in some way. Should I be concerned and/or is there any way of getting rid of the smell. I believe that the smell can be put down to dust inside mingling with a solder type smell and thus a "hoover out" might resolve the issue.
Graham
