is the BeoVision 9 modular ???
Hello Everybody!
daes anyone know if the BeoVision 9 is as MODULAR as the BeoVision 4?
I mean, I really like the fact of the BV 4 being so modular... in theory you could replace the panel after a while and keep the BeoSystem 3... and if you had a HDR2 you could keep that too...
would it be the same with the BeoVision 9?
thanks and many regards!
In theory yes.
The BV9 has the following: BL7-4, BS3, HDR2, Beomedia1 and BV4 panel. So in theory you can bay a BV4 and chance it if it still use the same bracket as it do today..
