Is It Worth Buying A BeoRemote One BT For The BeoSound 35?
As the title says I'm considering buying a BeoRemote One Bluetooth to use with the BeoSound 35 in the bedroom and wondering if anyone else uses this remote with the BS35? Not a fan of having my mobile phone in the bedroom and would like to be able to control when in bed and also have the Lutron Rania B&O Light Switch to use with the BeoTime so would be nice to be able to use this remote to control and turn out the lights and wondering if the Bluetooth version can still do this? Know the original can as I use in the Sitting Room!
Sitting: BeoVision 11-46 on Motorised Floor Stand - BeoLab 11 Wall Mounted - BeoRemote One - BeoCom 5 with Speaker Base Dining: BeoGram 3000 Type 5228 - BeoSound Core - BeoLab 28 - BeoRemote Halo Kitchen: BeoSound 1 - BeoRemote Halo - BeoCom 6000 Bedroom: BeoSound 35 - BeoRemote One - BeoTime Guest Bed: BeoLit 20 Study: BeoSound Core - BeoLab 8000 - BeoCom 5 on Speaker Base Gym: BeoPlay A9 On The Go: BeoPlay H7 - BeoPlay H5 - BeoPlay E8 3.0 - BeoPlay H95 - BeoPlay EX
The bluetooth version of the remote does not switch between bluetooth and IR. The BS35 has a IR sensors so you can but the remote in IR and control your lights and the BS35.
Thank you so much L1NO just figured out how to pair the original BR1 to the BS35 via IR and indeed that it had a IR sensor, you’ve made my day and can’t thank you enough! Will order the remote and keep in IR.
