Is it possible to TURN OFF 100hz on Beovision 7-55?
Hi, I wonder if it is possible to turn-off 100hz on Beovision 7-55
Regards
BeoVision 7-55 is a 200 Hz TV and it is not possible to turn off
I think this one is actually 200-250Hz . I don't think you can - why do you want to?
Maybe it wont work to shut the 100hz off. BUT: BV 7-55 is a 100hz-screen and nothing else. In the tecnical specifications it says 100hz AND in the "customer meny" You can read "panel output" as 100hz.
Regards
The Bv 7-55 is a 100/120 hz screen.
A really interesting thread, but I don't know the answer.
Astounded when I first saw the quality of Avatar on the 7-55, so as any decent human being would do I went out and bought the Samsung 55" panel with Freeview HD and 4 x 1.4 HDMI, 3D CAPABILITY via compatible player and so on.  £2300 seemed great value through the trade!
Stated specs for this are 200hz Motion Plus, so maybe Samsung have added some electronic processing which B&O have not.  When I get back from a short break I will check to see whether Motion Plus can be turned off on the Samsung, and if so what the refresh rate is when it is off.  I would be very surprised if you can do anything with the B&O product without meddling in the Service Menu.
Had a quick flick through the service manual. The screen is 100/120Hz refresh rate - I had thought it was similar to the BV10 but was wrong. I cannot see any setting to turn off the 100Hz.
