Hallo
I've a question: is it possible to connect an Ouverture to B&O passive speakers like CX100?
Hallo
You need some amplifier, B&O recommands MCL2P.
Search the forum for this.
Ralf
MCL2P is out of production since years, the recent version is called "ML/MCL Converter"
Both versions will need a fully mounted PowerLink cable.
Vienna,
you are right! Now the ML/MCL Converter is there (or Beolink Passive without the IR eye).
But amagian could try to get a used MCL2P... CX100 and Ouverture are out of production since some years, too.
Ralf
