Hello All,
Maybe im not the first one to ask this question, unfortunately i couldnt find any thread which was disucssing my queries. In case you see if it is already discussed please point me to the link. Thank you.
I recently upgraded to B&O from B&W speakers, and i still have the same setup with B&O speakers now. I have:
> Marantz SR6006 AVR which has pre-out
> Beosound 8000 as front and Beosound 6000 as rear and 7.2 as my center speaker
> have pv1 subwoofer
My project now is to make the B&O speakers connect wireleassly. Atleast 8000 and 6000 ones. I checked the option of Beolab transmitter and receiver. It comes bit expensive as i will have to have 4 receivers. Is there any tight requirement that the wireless transmitter and receiver has to be powerlink ? please educate on this. Can i use any available Wireless transmitter and receiver ? If yes which one would you suggest.
Aprreciate your time and patience to go through my query. Would thank you tons if you suggest me a solution fitting in my budget of less than 500€. Thank you in advance.
-BR
Dhanu
