IR eye - BLC NL/ML
Hi all,
Quick question regarding IR eye, can a older version with PL cable be used on a BLC NL/ML converter (with RJ45 connection) using a normal speaker PL to RJ45 adapter? I can’t figure out how to get the IR eye work on de BLC and suspect the adapter trick is not working.
Thanks for sharing your thoughts
I believe the wiring is different. You have to use the Join version instead of the Play version.
This might help
Millemissen wrote:
This might help
Great this helps! Thanks
You are correct, I got the join version from my dealer and it is for NL/ML - Essence mk2 - Core.
New question, anyone know if it is possible to change sound settings for the connected BL’s? If I select A-Setup on Beo4 I see bass-trebbe-loudness but cannot get it to react on anything.
