iPhone / iPad/ iPod possible port/pin change in new models - older B&O Products
Apologies if this has been posted, I did try a search first.
Rumours are that Apple are going to change the charging/ docking port to different pin combinations.
http://www.iclarified.com/entry/index.php?enid=23414
Will B&O Produce anything in order to stand new products in the Beosound 8 dock or iPort? Leads are a good idea but no for a dock.
I have also been thinking about this. Especially regarding the Beoplay A8. Since the dock is removable they could start to sell a new dock which would not change the esthetics of the speaker and one could simply swap docks depending on which device one is using.
With the Beosound 8 they could introduce an adaptor from the existing 30-pin connector to the new (19-pin?) connector and if they do not, other companies probably will (apple being one). This would however be visible...
Try this
http://www.guardian.co.uk/technology/2012/jul/24/apple-connector-iphone?newsfeed=true
There is always AirPlay!....................no wait
