Trying to use FM Radio function of BM 7000 by
Using A/V 7000 as preamp for Active Speakers front/rear/sub
Connected both via 8 pin Din Power Link cable without success.
Remote Beolink 1000 controls both units. When Radio is selected both receivers respond but no sound.
The only way I can get it to work is when using tape 1 on BM 7000 output feeding A/V 7000 Aux input, but then I have an issue with operating each unit separately to select Aux on one of them and Radio on the other.
Question:
Is there any other intelligent way to interface both units to work as one?
Or there is a way I can disable IR sensor on BM 7000 after selecting Radio function?
Then I could power it on/off manually with Radio function selected.
