Hi all,
as some of you already know we are currently working on a PCB that allows you to connect a LINK TO THREAD
If you like to tinker the possibilities are nearly endless. You could build a DIY ML gateway or just add two additional sources like N.Music and N.Radio for AirPlay and webradio. E.g. you could program it that it automatically switches on your system or just a specific linkroom when selecting AirPlay on your iPhone.
A high quality DAC on the same PCB will be injecting all the audio from Raspberry Pi into the ML system via a RJ45 ML connector.
This thread is about to find out how many of you would be interested in such a solution.
We want to keep all HW files and SW that is developed to control the ML open source and freely available.
But when it comes to manufacturing PCBs the more you order the cheaper it gets per piece.
The quantity is also imported in the phase of designing the HW layout which we are currently in.
So let the discussion begin... :-)
BR,
BeoMotion.
