Interconnetcions btw BeoSystem 3 and BeoVision 4-65 - may I use a HDMI-HDMI cable?
It is DVI + serial. I have a 50mm hole for cables and cant use DVI-DVI cable. Can I use HDMI-HDMI with 2 adaptors DVI-D-HDMI?
Whether the analog lines from DVI-I are used for sending video or only digital lines are used in these interconnections?
Yes, I can confirm this will work. Just make sure that you tape the adapter plugs onto the HDMI cable so that they do not work loose.
 Vinnie.
You can use hdmi to hdmi ( 10m max) with adapters. Have done 10plus with no problems.
Good Luck
