Integrating NL and ML in the new age
When you use the GVA feature, you use the Chromecast protocol and the sources within Chromecast (including Deezer). That’s why you cannot join from other B&O devices. You are outside of B&O multi room functionality.1) Google voice assist: if i play music using google assist on my BS1, i cannot “join” other b&o devices. The only thing that works is to cast to a group (“hey google play to speaker group a”). This only works for CC/CCA enabled devices. B&O app cannot be used and “join” is not possible. Join/app also not possible if i were to use deezer? Also not on my spotify connect devices?
Hello Steve,
I can not comment on the questions you made, at least not at all of them (every setup can be an "ecosystem' of its own) but I can share my setup and opinion.
I own a Beoplay V1, a moment, a beovision 6-26, a beomaster 6500, a beogram 5000, a couple of beolabs, a beolink pc, some beolink ml/mcl converters an NL/ML converter and a BLI (Beoliving Intelligence).
All ML products are connected together via an ML distributor and all NL products are connected to my router. The NL/ML converter is connected to both the ML distributor and the router and makes the link between ML and NL products.
The goal of my setup is to have all sources available at all rooms and be able to operate them via mobile app and ir remotes.
To achieve so I had to fiddle around with the nl/ml converter a lot and finally I came up with a solution which achieves the previously mentioned goal with a twist. The twist is that to initiate on an ML product an NL source you need to use video sources. For example when I press V.AUX on my beo4 my beovision 6-26 will play the pattern play source from my moment. To do so you need to "declare" the NL/ML converter as a video master. The result is that the ML products will "see" as audio sources the audio sources of the ML audio master, in my case the beomaster 6500. Then you can assign at the video sources of the nl/ml converter the audio sources of the nl products.
There still are some tricky parts like the fact that beomaster will play phono when n.music is selected but the beolink pc will play net music but these are not of a big concern to me as my beolink pc is quite far from my beogram so I am not listening to LPs while I am working in the office.
The beotech part of this site was very helpful along with steve from sounds heavenly who procured all cables for my setup. The rest is imagination and trial and error.
As far as the google assistant is concerned I am not using it although it is possible since the BLI communicates with IFTTT. The reason I am not using it is that my mother language as well as my wife's is Greek and it seems very funny to speak two languages in our house.
About the DLNA: I own two NAS, one qnap and one sinology. They both can be used as DLNA music servers but you have either to install the twonky app on them which is a bit of a struggle or use a plex server as the DLNA server. I am currently using the latter but it is not very stable.
If you follow a similar setup your video ml products will start without the screen being turned on.
The NL/ML converter is installed in my living room along with the moment and beomaster/beogram. All ml products are connected to the converter along with an ir eye. The Powerlink socket of the nl/ml converter is connected to the line in of the moment. The moment is declared to be in the same room with my beoplay v1 (although this is not physically true. The reason is that I want it to be ir blind). Furthermore the beomaster is opt.0 so it can not receive ir commands. All other ml products are opt.6
I hope this was helpful or at least inspiring for you to try and make your own setup the way you want it to function. At the end this is the reason why we love B&O....everyone has an installation that can match no other! ;-)
Hello again :-)
I am using both the B&O app and the Beoliving Inteligence app. They actually are quite similar.
As far as the nl/ml converter it does not support playback of any source like deezer etc. but if you want to add a deezer source for example you can hook a chromecast device on the line in. Then make the right adjustement through the gui of the converter so it turn on when you select the chromecast to play.
I haven't tried it as I am trying to use only one app. The B&O app before I purchased a BLI and now the BLI. As far as syncing you can play with it on the converters gui. At my setup I have never had issues with audio sync except with the beovision 6-26 which is in my bedroom and the only way to listen that it is not synched is if you stay at the corridor which leads to the living room.
Another idea that came to my mind which will permit you to add deezer etc to the line in of the converter and being able to control it through the B&O app and IR remote is to connect a beosound essence or core. I can not find of any use of this kind of setup other than making the converter a source of deezer etc.
Finally I believe if you connect a chromecast to the line in of the converter you will be able to make your beovision 7 join the experience if you program the converter to play line in when a specific source is selected. For example:
Let's say that you have only the converter and the Beovision 7. At the sources visible to ML page of your converter you can program it so when you press n. music for example what the converter should do is to play line in. If you do so though you would have to start the chromecast first and then choose n.music from your beovision. Whereas if you get an essence (mkii is the multiroom version) or a core you can program the converter so when you press n.music deezer should start for example.
To make it clearer.
The chromecast scenario.
You select n.music at your beovision 7. What will happen is that beovision will ask the converter to play n.music. Your converter will be programmed that when n.music is asked then is should play whatever is on its line in. So the beovision will turn on (without the display being turned on) and start playing the converter's line in. If you haven't started streaming something to your chromecast you will hear nothing. As soon as you start a stream from your mobile to the chromecast you will be able to listen it on the beovision.
The core/essence mkii/moment scenario.
You select n.music at your bv7. bv7 asks the converter to play n.music. The converter is programmed to play music (at our case deezer) from the core/essence mkii/moment. When asked to play n.music. the core/essence mkii/moment starts playing, your bv7 turns on with its display off and you have sound from your beovision.
If you are planning to play around a bit try to use a chromecast at the begging so you get familiar with the converter's possibilities. Then you can revisit your needs and goals and decide if it makes sense to buy a core/essence mkii/moment.
Don't forget that you will have to be patient. When something doesn't work usually you need to unplug from mains and replug the ml products. This is done cause every time you plug them to mains they run a "discovery procedure" let's say, of your other ml products.
ML is great fun cause it is a bit more demanding than NL as far as installation is concerned. NL is much easier and straight forward.
Which NL products do you have? The nl/ml converter is used to integrate nl and ml products. If you only have a bv7 and the nl/ml converter there is not much you can do.
The way I have integrated nl and ml products in my setup is the following:
All nl products connected to the router.
All ml products connected to the nl/ml converter except the beomaster 6500 which is not an ml product but a datalink product. To make it communicate with ml products and the nl/ml converter I used a beolink converter (https://www.beoworld.org/prod_details.asp?pid=983).
The nl/ml converter is hooked to both the router and the ml network.
ML/NL converter does not function as a source but as a "translator" between nl and ml products. The only situation in which it functions as a source is to play whatever you have connected on the line in. You need to have an audio master (it doesn't matter if it is ml or nl) so you can have access to music sources. An audio master can be a moment, a core, a beomaster , etc.
As far as the beosound 1 is concerned it is not compatible with the ml protocol so there is not much you can.
You can use the beotech site to check the compatibility of different products.
if you don't mind sharing with us the products that you have I can help you further.
