Hi all,
I have a Beomaster 5500 in my living room. I’m considering putting a pair of CX50s in my kitchen and somehow connect them to Beomaster 5500.
I also like the Beolink Passive in a combination with a circular IR eye. I was hoping to enable/disable speakers in the kitchen and control the volume with the IR eye buttons.
Since Beolink Passive uses MasterLink I was wondering whether integrating them is possible.
The way I understand Beomaster speaks Master Control Link (MCL) and Beolink Passive speaks MasterLink (ML) and you have to “translate” that.
Can this be achieved by using a Beolink Converter to translate MCL to ML? Then connect the Beolink Converter to the Beolink Passive ML?
The thing that also confuses is the audio signal level. In MCL the audio signal is at speaker level. I imagine this signal should be somehow attenuated to line level for the Beolink Passive.
I feel like I’m missing something out here and I would really appreciate some help.
