Hello,
I (tried to) install an Atlona Juno 451 HDMI switch with a BV Avant 75 in order to have multiple HDCP 4K source (there is only 1 port).
So far I had some difficulties to have it working... Here is what I did :
- I connect the HDMI out of the Atlona to the HDMI1 of the TV.
- I connect the first 4K source to HDMI IN 3 of the Atlona
- I connect the second 4K source to HDMI IN 2 of the Atlona
- I plugd the power supply and turn the Atlona ON
- I turn ON the TV and went into the INTEGRATION menu and select a matrix switch, get the right PUC code, select the matrix in the list and assign it to HDMI 1
That's were it gets a little bit messy. I assign the 1st 4K source to MATRIX3 and the 2nd one to MATRIX2.
I was not able to have them working. I verify the cabling, and every time I select the right source, it did not powered up the right equipment.
I suspect a problem on the IR side of the setup, but when I plugged back the source into their older HDMI ports on TV and reassign everything, it was back to normal...
I am sure I miss something, but I am a little dry on the test I can make... Any ideas will be appreciated !
Cheers,
Serge
