Hi Steve
Thanks for finding he time to try and help.
The main part of the house is served by a traditional audio and video master via ML, which is great for distributing sound to various rooms but being an older system means that everyone has to listen to the same thing.
In the music room, I'd like to be able to have a choice of either listening to the same music as everyone else or playing something separately via the Beocenter 9500.
The music room has a single pair of passive non B&O speakers.
The nub of the problem therefore is how best to feed the speakers from two separate sources in the most elegant way possible, ideally using a single B&O remote.
I have a spare beolink passive and MCL/ML converter which could potentially be used.
The options as I see it are:
1. Use a MCL/ML converter (which I have) to pick up from the rest of the house and feed into the Beocenter - unfortunately this creates a network with 2 master auto units.
2. Use a speaker switching unit - the downside to this is it would most likely be a manual switch and not a B&O solution controllable using a remote.
3. The third option which would be to connect output from the passive into the Beocenter - the idea here is to be able to select local sources direct rom the Beocenter or pick up linked sources via the passive/2nd ir receiver.
The solid connecting lines show the current set up, with dotted lines the optional connections as I see them.
Many thanks for any advice you may have.
Alan
