Bayerische you have previously said:
Keith Saunders:
With regards to the Plasma radiation issue highlight which limits or stops some IR transmissions, this is not related to the Beo5, but is a general problem for which there are several solutions. I will highlight this further in another thread.
Keith, that's another huge problem I would like to get rid off!
Now I can't use my Beo with my screen on.
My comments:
Most plasma screen produce a large amount of Infra-red light which can "overpower" the infra-red signals from your remote control particular when the display is very bright.
There are many solutions available from the simple opaque cover for the infra-red receiver through to a receiver and re-transmit product.
However, before you look into a product solution for this problem consider your configuration and where the infra-red receivers are in relation to the Plasma screen. If for example they are directly under the plasma screen and you are using the remote directly in front of the screen, then you are most likely to have the problem because the strength of the infra-red light signal from the screen is greatest directly in front of it. The greater the angle from where you are sitting in front of teh screen to the IR receiver then the more the interference will be reduced.
I suggest you describe exactly where everything is in relationship to the plasma screen and what devices if any, work correctly and which do not and then I think we can come up with some proposed solutions.
