My dealer is telling me that it is impossible to do the option programming in such a way as to solve the problem I am having. Thought I would post it as a sort of a puzzle and see if anybody here has a solution.
Room 1 has a BV7-55 and connected speakers.
Room 2 has a BV10-40 and connected speakers, along with a Beosound 5 and a Beosound 3000.
Here is the problem. If I set the BV10 as the Master, then the timer function in the BV7 is not available. If I set the BV7 as the Master, then the timer function is available and works perfectly, but......if I turn the Beosound 5 on by using the Beosound 5 itself instead of a remote, that turns the speakers on that are connected to the BV7 in the other room, instead of turning on the speakers connected to the BV10 in the same room as the Beosound 5.
Any option programming solution that will allow me to use the timer on the BV7 and have the Beosound 5 activate the speakers in the room it is in?
