Hi
I'm looking at buying my first Bang & Olufsen and would like some advice please. This is my first post so apologies if its in the wrong section.
I like the style of the upright David Lewis systems such as the Ouverture, Beosound 3000 and 2300. (I've ruled out the 3200 as the cost at the moment is too much) I've seen Ouvertures on ebay and second hand dealers from anything between £300 and £800 but what I would like to know is what to look out for and the advantages of a particular system over another. I'm not too bothered about the cassette deck but I would like to be able to connect my ipod and my Sky box so I can listen to digital radio. If it helps I have a medium sized house with 2 reception rooms and eventually I would like to be able to have a multi room setup. I've heard talk of small & large clampers but don't understand the difference and if I buy one from ebay I'm concerned about the glass doors functioning correctly. Also I was going to start with some Beolabs 2500 or 6000 (again 8000's bit too pricey) but again would like advice on this please.
Many thanks in advance.
David
