I'm really stuck - scart question
Our BV3 has 3 scart sockets at the rear, and we just bought a new STB (Philips DTR7200).
The old STB has been connected via scart which has been perfect, but our problem is now that the new STB does not have a scart output socket (see image below) how do we connect our new STB to the TV? I have tried one of link cables, but with no success, which does not make sense. [:'(] I also tried using one of and it worked, but surely there is a proper cable to use!
Please somebody help, i don't like not knowing what to do!
The first one is the best to use, RGB with R,L audio to scart. It sends the same Standard def picture a scart would send only it doesn't send control commands. There will be no loss in quality, unless you use a cheep one. You may need to go into the STB's menu to change the output to RGB.
Check that your scart has all the connections. I have scart plugs that have different sets of pins, depending upon what you are using it for. Could be yours is intended to take a signal OUT via scart to rca-plugs.
But also give the setup menus a look, as suggested above.
it's a bit hard to tell in the first pic, but doe's your scart have 6 cords on the other end? if so often, they are labled wrong (this is most infuriating). Sometimes the in's are out's and somethimes the out's are in's. etc.
This being the case it's also probably safe to assume that the scart's with only 3 on the other end can also be labled incorrectly.
however, assuming all the cords are in the right holes this cable should be fine.
jazz
Just to give you an idea: (S-Video, 2xRCA to Scart)
 Link1
This one has good qualtiy, not several plugs...
Maybe this one is enough: (S-Video to Scart)
 link
Because you need a coaxial digital audio cable to the BV3 (if DD built-in). link
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thanks for your helpful suggestions. I disected out Scart cable to learn all about how it works and i made my own cable, but it was not very good quality, as it broke. I then tried a brand new S-video cable which cost $20 - to a scart adapter, which was truly a disgusting result in picture. Ick! I got what i paid for. I finally realised this when i disconnected our DVD which is via Scart, and watched a DVD with the S-video cable - just horrific it was!
Contemplating sending the STB back (as so far the picture quality is alot worse than our current STB), I realised it is in the connectivity. Tommorow i am on a quest to find the right interconnects, before i reject this machine, which has otherwise received terrific reviews. Ah if only there was such thing as a HDMI to Scart cable!
I will try the products you describe kallasr, as this should be the most effective method of connection.
Oh, another issue with the new (& non Scart) STB, is that every time the TV is switched over to SAT / DTV the aspect ratio reverts back to Format 1 (4:3). Very annoying, is there anyway of keeping it on Format 3 (16:9), instead of having to adjust it every time?
David,
 this is somewhere in the Forum - referring to an Avant 32. Maybe this helps:
 "Hi under format 1 there are 3 "sub formats" 4/3 - 14/9 and 15/9 or 16/9 depending on model.
the thing is:  you last used "sub format" is the one it will use as default when in format 1. you change the sub format by << - >> or up and down (depending on model) when it's in format 1."
 Ralf
Check the output of the STB's software is set to 16:9, some boxes call it letterbox format.
Hi David
The best way to do it, is with an S/VHS cable and the scart adapter. I think the 16/9 issue is gone with that
You will get the best pic with S/VHS.
