IC chip STB-C version 4.06
You may also wish to view all the recent Central Europe updates
Hi Keith,
Could you confirm that the latest STB-C IC for the UK is 4.11?
I have written to B&O and they claim its 4.10
Version 4.11 is the latest available.
You can review the complete list
Thanks Keith...I knew you'd be right!
if anyone has for sale a Central Europe IC Chip ( any version 4.02, 4.06 or 4.12), I would really be grateful if they could get in touch, thanks.
if one has an old STB-C with IC Chip ver 3.6, can you simply change like for like a newer ver 4.06 or later chip ??
thanks
Peter
Peter,
The simple answer is "Yes you can"
The Chip is cheap, just get in touch with your local B&O Dealer. They can order any version, it's not like you could only order the local version.
that's good to know, will contact my dealer on Monday,   many thanks
