Does anyone know which Set-Top-Box devices are supported by the IC chip version 4.06 STB-C?
It is not installed so I can not check it via the TV-menu.
Do you have the lists for the other regions as well ?
I would also be interested in knowing if the list of supported devices for other European regions (specifically UK)
Check
Many thanks for sharing the file !
But I still would like to know the complete list of version 4.06
So if someone can help me with this ?!
I think the following list is what you may be looking for:-
Many members in the UK will be particularly interested in the fact that the Virgin V+ is included in the list which was a pleasant surprise.
West Europe 4.11
1. HUMAX Cl-51 OOC
2. Humax IRHD-5000C
3. Humax IR-FOX C
4. Humax IPVR 9200C
5. HUMAX PVR 9200T
6. HUMAX HDCI-2000
7. Philips DCR 1211/18
8. Philips DSR7005
9. Philips DCR 7101/03
10. Philips DSR7121/22
11. TF4000PVR
12. T.FIELD 771 OHDPVR
13. TF5800PVR
14. TF581 OPVRt
15. TF5000PVR
16. MOTORO. DVi5000
17. DREAMBOX DM7000
18. SA Exp 8455DVB
19. Virgin V+
20. BT Vision
21. HUMAX FOX SAT HDR
22. Technomate TM5000
23. PACE SKY+
24. SKY DIGITAL
25. Apple Remote
26. ASTON XENA 1600
27. KreatelIP-STB 1760
28. SAMSUNG DCB9401
29. SAMS. DCB-H360R
30. Samsung DCB-B270R
31. Samsung DCB-P850RS
32. SAMSUNG SMT1xOO
33. Sony Playstation 3
34. CANALdigital B+
35. CANALdigital NL
36. indi 5800C RAW
37. STARHUB
38. TELENET DBAD101
39. Belgacom TV
40. TViX M6500A HD
41. Thomson DCI52NUM
42. Thomson DCI62UPC
43. Thomson SkyHD
44. REBOX RE-1150CO
45. REBOX RE-1250CO
I'm afraid the Ordering number for the new Chip is the same as the old one. So i belive you can't order it anymore (shrug maybe im wrong and you somehow still can manage to get one). I got the list on my laptop, can check tomorrow if you still need it by then.
Yes please, that would help me. I do have the IC chip 4.06 but not yet build in my B&O TV.
Before doing so and dismanteling the rear cover etc. of my TV, I would like to know which devices it supports to prevent that all the work is done with no results at the end 😮.
Many thanks!
