hello all,
i purchased recently this
hello all,
Not knowing the specific product I guess the easiest solution would be to connect it to the AUX port on the BS2300
Suggest you ask the company that sells this. You could designate the 2300 as something else I suppose.
the aux port on the bs2300 is already occupied by the ML cable....🙁
