I need a cabinet for my BeoVision 4 50" HELP
I have been advised that the B&O cabinets do not support a BeoVision 4 50". I need some sort of cabinet.
Any recommendations as to what make to look for?
I also remember a new company who built cabinets purposefully for B&O equipment!! what company was that?
Cheers for any help.
http://www.struerdesign.co.uk/
Did you mean this one?
Do you mean something like this
http://www.dwr.com/product/furniture/living/media+storage/muro-media-storage-unfinished.do?sortby=ourPicks
something that holds your screen?
Spectral make some nice TV stands. Very good build quality, my parents have one.
Regards,
Robert.
I've been looking for a small cabinet that would raise my 28" Avant about a foot higher, yet can withstand the 60kg weight.
Any suggestions guys?
Hi Scotty -
In fact, the B&O large cabinet #1218666 (http://www.bang-olufsen.com/cabinets) is designed to support a BV4-50 on table stand.  My brother has his BV4-50 on one; mine holds LPs and a BeoGram.
It's sturdy, strong, and really well-made.  No complaints.
Good luck -
Looking good folks!!
Any prices for them in the UK?
The B&O cabinet shows only speaker on it, are you sure it will hold a 50"?
I've stood on top of mine, based on that it will hold.
