I have just put an order on the Beoremote Halo with tablestand.
Does anyone know the "roadmap" of the coming software updates and which features that wll be added?
Best regards
Best regards
Hi, does anyone know if you can change volume on the Beolab 50 directly when you have an external streaming device connected directly to the Beolab 50?
The Halo is using wifi and the that should be possible when the labs 50 also is using wifi.
Maybe Mikipedi knows this!
Best regards
Best regards
Indeed it certainly not possible with the Helo.
Amazing huh?
t Hi, does anyone know if you can change volume on the Beolab 50 directly when you have an external streaming device connected directly to the Beolab 50? The Halo is using wifi and the that should be possible when the labs 50 also is using wifi. Maybe Mikipedi knows this! Best regards Martin
Doesn't work as of today, is technically possible, I am unsure if it'll be in the next big update. From what I gather they're looking at it, but I don't know what that means as of yet.
Miki,
do you know the date for the « next big update »? Spring? Summer?
Hi, It seems that I can not save a Favorit from Deezer with my Halo. Is it a sw bug when using it with Eclipse V1?
Does this function , saving favorites, work as it should with Beovision TVs (eclipse/harmony)?
Best regards
