I gave up my B&O receiver (Beosystem) for an Onkyo!
Is there anyway to connect BS 9000 to a Onkyo receiver?
Yes. With the help of a A.Aux out to RCA adapter cable, you can send the audio from your 9000 to your Onkyo.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
hi everybodey, i have connected my Beolabs to an Denon AVR-3312 (Pre-outs). It is is working well so faar. One thing makes me cracy and i haven't found a solution till now:
When i switch off the sytem, there is i noise comming out from the Labs (2x 8000 Front, 2x BL3 rear, BL2 Sub, BL6000 Center). If i power on the system it is perfekt,i hear the relais of speaker an everting is ok. When i power off, then ther is coming a short noise befor the speakers switch off. I use a 5V Trigger to Pin 4 (Speaker) for switching on and off.
I would be happy if someone has a solution or a recommondation.
wood
Hello,
after following the forum for some time, this is my first message, triggered by these tremendously helpful postings!
After my old Avant has stopped working I considered a long time buying a new B&O TV, mainly for linkroom connectivity (BL3500 and 2 BL2000) and the speakers/system in main room (BL8000, BL4000, BS3200) Finally I decided against and bought a Samsung TV given the picture quality/web-/tab-connectivty/pricing mix of B&O is just completely nowhere (even 2nd hand).
To get speakers and systems linked, I considered a while buying a 2nd hand BS1/BS2 only for sound, but your Onkyo-option seems a lot more interesting....The plan would be 1. to buy one of Onkyo-amplifiers, 2. connect all video sources/TV via HDMI to it, 3. connect all BL via Powerlink/RCA, 4. connect BS3200 via AUX.
My question is: The only shortcoming I see is that I couldn't access video sources in the link rooms (as Onkyo evidently has no Masterlink)...Is that right?Or are there any other surprises besides the speaker on/off problem mentioned before here? Eg, do the speakers automatically go on, if I use the BS3200 keyboard to play audio? Can I change audio volume on the BS3200? As I personnaly like very much the Beo4, I would use my Lintronic box to program it to the Onkyo IR-codes - is there any issue with that???
Thanks alot in advance for your sharing your experience with that!
I don't think you will have any trouble getting the Lintronic box to command an Onkyo receiver. I would definitely be one to try and integrate the 3200, that's just me. But I would be saying to myself the entire time, this is crazy! 😂 My best advice would be to just integrate the Beo4 and Lintonic box.
At present, I am considering a Yamaha HTR-5790 for my compact active setup. It would be a ton of hardware for just a two channel preamp need, but the receiver has the ultra rare twin switched power outlets I have been searching for. These would power my speakers directly (they have no dc trigger). The price is definitely right -its used- except it is missing the remote. Lately I've been reading the 5790 absolutely relies on the remote. Bummer. I love Yammie gear and really don't want to let this one pass me by but I feel like I have to.
Check here too
Retired
Printing machine technician
Rock and Roll music
Collecting Vinyl
