I'm from the UK and used to masonary walls so wanted to ask before I make a mistake here but B&O tvs are made of proper materials like glass (not plastic) and therefore weight quite a bit more than normal consumer ones, especially when they're a foot away from the wall and thus adding more torque,
My main concerns before I proceed with doing a wall fitting myself:
1) Are hole positions and stud distances standard everywhere? Ie do the holes on the Danish made wall brackets line up with the stud positions in the US?
2) Would I be better bolting a wooden mounting plate to the wall? Or opening the dry wall and adding a beam between the vertical studs?
3) I'd rather use new bolts/screws than recycle ones that have already been stressed, what sort of spec are they?
