Got a BV11-46, NL/ML converter.
But how do i get the Beomusic app to work?
it's searching and searching but nothing happens.
Any hints?
Any hints?
You need to have an NL source (like e.g Essence) in your setup. BV11 is not a source that Beomusic app can talk to.
So sad.
at least you have the beoremoteapp
Of course!
I am not sure if this is correct. I am using the Beomusic app with my Beovision 11 to add it to a multiroom setup. I do have however also other NL sources in my setup, like a Moment or a Beosound 1.
Yes, in a setup like that you can use the Beomusic app to e.g let Beovision 11 play what is currently playing on e.g the Beosound 1.
It''s a shame that a televion system like the BV11 cannot be used with the Beomusic app.
It is actually very simple.
Beomusic is the app for controlling music in a (B&O) multiroom setup aka NL - thus you will need at least two NL capable components in the setup.
