How to start with B & O
Just wondering what would be a good equipment that can be controlled by BEO4 , works like a receiver for my Cona subwoofer, 2x CX100 and 2x CX50. And allowing me to play different songs in different rooms at same time.
Gilly
The whole concept of the MasterLink was to play the SAME music in multiple rooms.
So for different songs for different rooms with your passive speakers I think the most economical path is too look at a vintage B&O system in each room.
But at some point you need to think about moving to the new world with wireless access from each room to the central server of songs.  This would probably mean replacing your speakers, unless you wanted to invest in a Beoactive amplifier for each room that operated in PC mode, and was connected to something like an Airport Express.
Another option that I am not qualified to comment on is Sonos .... I don't know if that would attached B&O passive speakers ............
What vintage would you recommend since as I said before Im just starting with B&O
It depends what design you like and what mediums you need for playback or recording.
Do you play vinyl?
Do you play/record cassetes?
Do  you listen/record radio?
Do you play cd's?
A need for Iphone and os forth
All of the above, none of the above or just 1 thing, 2 things?
Lastly do you have space? Some vintage B&O can take up quite a bit.
No vinyl, no cassetes.
I do listen to radio and play CDs as well.
Iphone "input" would be great.
Space I have an empty room just for it.
That could mean:
A Beomaster and a CD player.
BM5500,6500,7000 Beo4 can work and you can get good matching cd players. I had the 6500.
BM6000/BM8000 old classics early '80s with CDX. A great combination though to old for Beo4 unless you find a complete rare converter kit. I use this system myself
BM4500 + CD4500 Beo4 friendly. With only 2 units space is not a problem
BM3000/3300 + CD3300 non Beo4
Both 4500 and 3300 can be wall hanged
Beocenter 8500,9500 and 9300 fully controlled by Beo4 or Beolink 1000
Beosounds too .
Beocenters and most Beosounds have build cassette players.
If Beo4 is not important any Beomaster would fit and for Iphone they always have an aux type input.
If its an pre 1986 Beomaster the cd player would be the CDX. Post 1986 like system 6500 you get the units joined together with Beolink 1000/Beo4 and it sounds good + lots of connection options. You can always upgrade too.
I ve seen a beocenter 9500 on ebay. Might give it a go then!
How about controlling lights from a Beo4? Just realized that B&O exists when I went to my godfathers place, he has everything controlled by remote, in the toilet if you wanna change music, only aim to the speaker and it changes the music. How does that work?
Sorry about my questions but its just too much stuff to learn at once!
Thanks!
Controlling lights could be done with Beolink 1000 and Beo4 can control lights and a whole loot of other things just check list or ad to list. You will see what I mean.
The lights would need the LC1/2 units and power saving lights do not work. They come with an eye and is installed via the Beomaster/Beocenter were the light information is being stored.
Speakers in another room is done by the now old master link or mcl link which came first. The mcl Xtra speakerkit for Beovox passive or Beolab active speakers consist of a smal box with an eye for the remote. In any room you put up the speakers and the box + tranciver eye then 1 wire out to next room or Beomaster. It works well and I have done it. I had a Couple of Beovox CX100 in the kitchen and whatever I wanted to control with the Beosystem 6500 with sound from th CX's I could do with the usual B&O one touch to do anything kind of system.
The downside to the MCL system is that you might adjust the volume in all rooms if you reach a certain level of loudness.
In fact you don't really aim at speakers but the tranciver eye but once installed you don't have to point as much as it is that good to catch the remote signals.
Even if I use vintage B&O equipment does it still being better sound quality than a bose sytem or a regular home theater (2012 model)
To B&O fans part of it is the experience of it.
Once you get used to it, you will notice why B&O is different.
Old B&O, vintage B&O and new B&O all sounds great. There are a few not so good products and the older stuff might need a service to work right but it is always worth it in the end.
