Here are the canonical products available on amazon and elsewhere, from purpose-designed to generic: (1) SVS SoundPath Subwoofer Isolation System (ASIN: B00NCSQ5GK) and you drill holes into the tips of the legs to screw them in. (2) One of the various styles of "IsoBlock Silicone Isolation Feet" (incl. ASIN: B07QPBNKCL). You could use the largest style ("Bigfoot") upside-down but carve divots into the tops (i.e. bottoms) to hold the legs so they don't tip over/out. Same idea as @matador43's tennis balls above, and maybe harder to stick but more domestic looking; you might have to drill double-ended screws into the legs to ensure they hold as spikes. (3) Speaking of spikes (e.g. ASIN: B07B4B68TC), which I don't think are worth much but they mount with tape and look OK; the problem is making them work at the legs' angle to the floor. (4) Washing machine feet of various prices and quality: a fancy sorbothane set (ASIN: B00536VQE0) is pricey for what you get, but at least they appear to have thought about the material & design.
All are hideous, even the tiny spikes. Consider instead an "art" rug of modern manufacture, so it's broadloom, extra-thick&heavy with multiple materials giving density changes to help shift the vibration -- as opposed to a gossamer, flexible genuine hand-knotted oriental rug, which would look beautiful but not work as well. You can even hide an additional carpet pad under it.
(In a perfect world, there would be a double-ended bolt&nut cylinder made of rubber that you screwed directly into the A9, **so you couldn't see it** and then screwed the leg into that. They make such dampers, to hang HVAC systems, but they are usually engineered for heavier weights. As a result existing goods are too-large diameter and have just a single plate buried inside the rubber cylinder, made for nuts on threaded rods inside and hanger-plates outside. STB Brackets take note: requires custom manufacturing, but easy to engineer...)
Remember, these suggestions only work to reduce structure-borne noise. As @Jaffrey2230 points out, the bass itself can induce noise in balloon wall construction, and is very hard to fix unless you own the apartment and can do renovations. Remember the last time a "rice rocket" with subwoofers vibrated down the street near you? Same principle for your neighbors, if you turn the volume up and have anything but a concrete firewall between you and them. But the inverse-square-law works (although frequency does matter, see: https://physics.stackexchange.com/questions/194526/does-the-inverse-square-law-apply-for-all-frequencies-of-sound) so maybe just a few inches further away will do the trick. If you are still friendly with your neighbors, go next door and listen, while asking someone to move your A9 slowly until peace & (relative) quiet reigns.
Sorry to be so long-winded, but hope this helps. Take a picture of what you finally end up with and post it here!
