How to record to cassette from turntable on beocenter?
9500 with a beogram rx2 attached. is it possible to record to cassette from the turntable?
Yes,
       select "phono" and then press "record" twice on the cassette section either using the touch panel or remote.
Chris.
Thanks very much.
Actually when you push record once you can set the levels and dolby unless you use the auto setting.
