How to paint Beo4?
I have a few Beo4 remotes that have lost the paint around the corners and where you tipically hold it with your hands.
Do you know a shop there they could professionally paint them?
If not, I would like to try it at home. Any suggestions on the procedure for the best results? Should I use an airbrush? What primer and paint? Do you know from what metal is it build?
Thank you
Alfonso
Zinc based alloy, best bet would be ceramic coating, much better than paint...
Or just buy a new case and resolder the contacts. I found painting it didn't come out as I well as I wanted it too
A black Sharpie pen does a good job of touching up nicks on the case.
