How to integrate BeoSound Core in older Masterlink-system?
Hi all,
I'm a bit confused by the BeoSound Core.
Currently, this is my setup: BeoVision 7 with 2 BL20's and 2 BL4000's connected to it through PowerLink for Dolby 5.1, and a BS3000 connected to this setup using Masterlink for playing music through the BL20's.
Now, I'd like to add the BS Core to this system, with the highest possible audio quality (I don't have those BL20's just because of their looks...) and the simplest way of use.
How would this work out? Should it be connected to the aux of the BS3000 (but it doesn't seem to have an analogue output)? Or to the BV7?
Or (that would be fantastic!) could it be optically connected to the optic inputs on the BL20's, while still using the PowerLink for anything but music?
Any suggestions are very welcome!
Certainly they can be driven optically. That is my setup.
As to which input has priority, my GUESS would be optical.
I suggest you PM Geoff Martin for a professional’s opinion — I am only an amateur.
You need an NL/ML converter...
MM you are a legend 👍🏻💯
This would be best. It would give the best sound (purely digital connection with Deezer Hifi) and be easy to control (girl proof). I only hope it will work as you describe!
What happens if you connect the optical toslink to the Beolab 20 from the BS Core and in parallel via Powerlink the Beovision? Is there a priority on each connection in the Beolab 20?
Yes, MM is correct, the best option is to set the Core volume to maximum and link it to the Aux socket of the Beosound 3000 with this cable:-
[quote user="Steve at Sounds Heavenly"]
Hi jc,
The sound quality from Deezer should be at least as good as when playing a CD on the Beosound via this option.
Kind regards, Steve.
Hi Steve,
Really? So the aux socket on the BS3000 isn't that bad as it looks?
I hope you're right, because that would be a relief. I'm just not ready to totally get rid of CDs yet...
