How to connect my B & O overture to my Samsung lcd tv
Any ideas how to connect my overture to my samsung le40c750r2kxxu lcd tv
i do not seem to have audio out port should i use earphone port??
Welcome to BeoWorld!!
I recently bought an LG full HD tv and was floored when I found out it didn't have an analog audio output. It only had a digital out. Since my setup was short term I just piped my audio sources straight to the receiver.
Does your tv have a digital audio out? If so, I would buy a converter that switches it to analog and then send the signal via stereo rca > din cable to the Overture.
I'm an automotive audio and acoustic engineer. I design loudspeakers and full sound systems for new automobiles. I also dabble with studio, consumer and pro audio projects from time to time.
You'll want to connect it to the aux port on the left side of the back-side of the Overture as your looking at it from the front. Your local dealer should be able to get you the right adapter piece which would have two analog RCA connections on one end and the multi-pin connection on the other to go to your BeoSound. Hit the aux button on the front and you should be good to go. Your TV will have to have a RCA monitor output and you will have two volumes to consider. I hope that helps :)
Thank you for that advice will my blu ray player come through the ovverture or will i need to connect with more cables
The sounds depends on wether your tv will downgrade the HDMI signal to the ananlog audio out. Connect the blu-ray with HDMI to your tv and then connect as stated above to the BeoSound. Plug it in and find out :).
