I finally gave in and chucked my trusty Beo Avant TV (anybody want it incl DVD1?) which drove my Beolab 1, Beolab 2 subwoofer and Beolab 8000 speaker setup. I now use a Samsung (boring) smart TV and want to connect the B&O speakers.
How do I connect the Beolabs?
Some suggest the headphone socket adaptor, but that can only handle two speakers or can it be three incl subwoofer if having the powerlink connected serially? Would these properly control the speakers, i.e. will they switch on and off with the TV?
Reading on the Beohub S8 it seems a neater solution as I can then hook up more speakers? Again will these properly switch on and off with the TV and will the only remote used be that of the TV? The TV has optiocal out so that would connect to the S8 and from the S8 it goes to the Beolabs the conventional way via powerlink?
many thanks in advance for answers and tips.
