Hi all,
I am new on that forum and looking for help. I hope this is the right way to do.
Can someone help me in getting the line-in setups of the transmitter 1 changed. The issue is that I do not get the transmitter download the WLPSETUP.TXT file to the USB stick and the Manual is not very clear for this point. It just states:
- insert an empty stick into USB-A connector
- the Transmitter will then create a file on the USB memory........
but it does not 🙁
It is not said if the transmitter needs to be connected to the mains or not, how long the stick needs to stay in the slot etc.
I tried several times, but no success: the USB stick remains empty (FAT32, no files before use)
Thanks a lot in advance for your help
