Hello
I need help.
I just bought a BeoSound 4 (from 2006) and installed it in my active link system. Before I had a BeoSound 3000 in the same setup. I have connected a PC to the AUX at the BeoSound.
In the old set-up, I could activate the AUX from a link room by pressing "A.TAPE" on the Beo4 ....... this is NOT possible on the BeoSound 4.
If the "A.AUX" is chosen on the BS4, I can press "volumen+/-" on the Beo4 or manually press "on" at the active link-eye. But if the source is not activatet at the BS4 .... I can not access this source from a link room.
How to fix this?
