How to activate "A.AUX" on a BS4 in a link setup
Hello
I need help.
I just bought a BeoSound 4 (from 2006) and installed it in my active link system. Before I had a BeoSound 3000 in the same setup. I have connected a PC to the AUX at the BeoSound.
In the old set-up, I could activate the AUX from a link room by pressing "A.TAPE" on the Beo4 ....... this is NOT possible on the BeoSound 4.
If the "A.AUX" is chosen on the BS4, I can press "volumen+/-" on the Beo4 or manually press "on" at the active link-eye. But if the source is not activatet at the BS4 .... I can not access this source from a link room.
How to fix this?
I have no direct answer, but solved a similar problem at home: activating A.AUX on BeoSound Ouverture from the link room. Using a Beolink 1000 instead of Beo4 I press PHONO which works the same as A.AUX.
... but this unfortunately doesn't work on BS4. ยง:-( ....... neither does "A.TAPE"
I just did a small test with my BS 4 and a Beo 4.
A.AUX started the BS 4 in the main room, and I then put it in standby (red dot).
A.AUX from the Beo 4 starts the BS 4 from a BV8 link room. Again I put it in standby.
A.AUX from the Beo 4 starts the BS4 from a BeoActive BeoWireless link room as well.
I was also able to perform this last test with a Beolink 1000 control: just press "SHIFT" + "RADIO" to activate the BS 4's A.AUX.
Hope that helps !
If you have a BL active, it depends on the SW to make A.AUX work - as far as I know. We had a thread here some time ago. As far as I remember you need SW 1.6, SW1.1 and 1.3 won`t work. A.TAPE won`t work, because this should activate the internal SD card player (but should be possible to activate from a linkroom BL active...?).
Maybe N.RADIO (PHONO) doesn`t work, because the BS4 is N.MUSIC compatible and "expects" to start up a BS5....๐Ÿ™‚
Which audio devices (CD, RADIO...) can you activate via the BL active? Is your BL active set to L.OPT 5 or 6?
Stefan
Have you added A.Aux to your Beo4?
apologies, my mistake, I was tired - I tested in my BeoWireless link room not the BeoLink Active.
correct, and yes it does activate the SD Card (A.MEM)
... or a BeoPort and its attached Windows or Apple Mac PC/laptop
Yes, sorry, I forgot Beoport and Linkplayer...๐Ÿ™‚
Stefan
BeoLink Active and BeoLink Passive from SW 1.5 on can handle the "A.AUX" command or, if you
prefer a BL 1000, "Shift" + "Radio" ...
I assume that the BS4 is in A.Option 2 or 0 (If is connected to your TV).
Register to access the forums, reference material, and exclusive member benefits โ€” including our monthly prize draw.
