Hello Guys,
Is there anyone who could tell me if the beoplay S8 has a good sound at low volume (which is my goal) or does it need to be at high volume in order to deliver its potential?
Thank you, & have a good day 🙂
Regards,
Hello Guys,
Regards,
Well i used too have the beolab 14s 2.1 which essentially is what the s8 is, and at all volumes i felt like they sounded amazing.
To be honest with you i never felt the need to turn turn them up really loud as i thought that they had ample volume which lead to a satisfiying sound.
Thank you for your answer markiedee !
Hi mark did you get rid of your 14 ? What did you change to ?Well i used too have the beolab 14s 2.1 which essentially is what the s8 is, and at all volumes i felt like they sounded amazing. To be honest with you i never felt the need to turn turn them up really loud as i thought that they had ample volume which lead to a satisfiying sound. Beoplay A2
