How heavy is heavy
So lately I've been thinking about getting a TV for the bedroom and (because plasma/LCD is all the rage) there's some great deals to be had with second hand CRT models.  Being B&O, these should still last for years to come and I was thinking that I could maybe splash out on the Avant that I couldn't afford years ago when it came out.
Of course, one of the things that I know from this forum is that they're very very heavy, as are the Lab5s.  I was wondering if anyone could suggest just how heavy we're talking about.  I've lifted sofas and packs of slate tiles up my 4 stories of stairs.  Is it realistic for a friend and I to lift an Avant up?  Maybe if I have time over the next few weeks I might make a graphic comparing the weight of B&O stuff to real world weights like "10 volumes of encyclopedia" or "a case of beer"
They are extremely heavy: +/- 190 Lbs.
But, they are blessed with THEE BEST handholds in the business -making them remarkably easy to handle.
...and that is the sort of attention to detail that you can only expect from Struer.
extremely hard to lift by yourself but not to bad with a mate!
Bl5 are about 63kg/each.
Avants are about 70kg?
BV5 75kg
BV9 125kg.
...me and a friend carried mine up a flight or two okay!
I think my Avant RF was about 93 kilo
Ok, I went and got a B&O tv.  In the end I got a 26" MX3000 (it's just for the bedroom so I don't need anything huge) along with a video player.  Finally that the stack of VHS tapes is no longer "clutter" and my refusal to throw things out has paid off.
Anyway, I thought this was worth a followup to point out that beyond the weight of an item, I think the ease of carry is equally if not more important.  When I collected it, everything was screwed/mounted on a metal frame/cabinet thing and it dug into my hands like a piece of metal wire.  The talk about hand holds on the avant suddenly rang true.
I carried my 5's to the second floor by myself and its definatly not a thing I would do again... for sure!
63KG feels very heavy, even 2 weeks afterwards...
Stephan
Yes, the Avant ones are very good as are those on the BV3.πŸ˜•
CraigπŸ™‚
I do remember when I was young and away at school that when I came home for the holidays, a friend of mine used to come round and, each holiday, we were asked to move a huge sofa from the conservatory ( on the ground floor) to the top bedroom ( on the second floor). It was very heavy and huge. I never moved it the other way! We did have a theory that it simply sank through to the ground floor over time!
