How do you change the rear case of a Beosound 1? how much do they cost?
Just noticed a small crack in the rear case of my beosound 1 - how easy are these to change? also wondered how much a new or used one might cost?
Does anyone have any ideas on this?
Thanks!
Removal wis very easy. Just a view screws. You need to pull off teh grille first (just move upwards). Did it once to clean it. No idea about costs -> call your dealer.
Thanks Heribert I think I'll give it a go then.
