How do I turn the mechanical stand on my MX7000 with my Beolink7000
I have jost got my fingers in a fully funvtional Beolink 7000 RDS sw3.1 which I am very happy for - even though it is from the early 90's.
 However, I have a problem - how do I turn the mechanical stand on my MX7000 with my Beolink7000
Thank you in advance for your help.
Cheers - the helpless Dane
If you have a two-way MX7000 it should be: PICTURE left - right (??)
Stefan
Unfortunately it's not an easy question, because this knowledge depends on Your TV's sw version.
First of all: Does Your MX7000 supports Two Way communication?
Did You stored the TV in the BL7000's memory as a "two way" system?
If all answer is YES, and the motorised TV stand is working with the BL1000 (for example), than when You select the "PICTURE" on the BL7000, than You will find the "<STAND    STAND>" options on the BLUE area on the top left corner.
If these options are available, then simply press any option, and turn the stand :)
If these options are not there, or You will receive the ugly "Operation conflict" message, than we need to check the SW version in the TV to solve the problem :)
Good luck :)
As far as I remember up to Type Nr. 33/93 SW1.1 it was two-way.
Ralf
Living Room: Beosystem 4, Beolab 7-2 (Center), Beolab 9 (Fronts), Beolab 8000 (Rears), Screen: Sony KD-85XH9096
Home Cinema: Beosystem 4, Beolab 7-4 (Center), Beolab 9 (Fronts), Beolab 4000 (Rears). Projector: Sony VPL-HW55
Home Office: BeoVision 11-46, 4 x Beolab 3, BeoCenter 9300 (BLC 1611/ML/NL)
Dart Room: BeoPlay V1-40 on floor stand
Guest Room: BeoVision 7-40 MK IV, Beolab 7-2, BeoSound Ouverture
Thank you all for your help. It appears that AT's solutions is close to solve the problem.
Unfortunately when I choose "picture" on Beolink1000  pointed at my old MX5500 I had the choise of turning the stand, but that is not possible on the MX7000.
Thank you for your help, sir. Tour solution might very well work, however, I do not know how to store the MX7000 in Beolink7000 as a "two way system". If you could guide me to that my problem might be solved. Sorry for being so hopeless.
Best regards
Christian
If the current channel number is displayed on the Beolink 7000 while you are watching TV (not Sat or else), then it is already in 2-way mode.
Otherwise, PANEL, SETUP,  SYSTEM, COMPONENTS, VIDEO, TV, TV (again), STORE.
Thank you for your quick reply, sir. However, it did not work. It appears that the MX7000 sw 4.3 does not support two way communication (even though logically making the stand turn is a one-way operation) in my head). Can anyone think of an alternative solution? I also have non-B&O dvd connected to the MX7000 via Scart and DVB-T Brainwave adapted to work with a B&O remote (and it also works with the beolink7000.
Once again thank you all for your excellent help - much more competent than my local B&O dealer (and I live in Copenhagen where their flag ship store is).
Best regards
Christian
My Avant is one way, and I can turn it with the Beolink 7000.
I press "Picture" twice on the red display, then the >> and<< on the blue display.
Don't know if this helps with your MX, but worth a try.
Andy T.
Thankx Andy T.
I think I need to store the MX7000 in my Beolink7000  first - but then your advice should work.
Thank you once again.
Regards
Christian
Slightly thread hijack:)
I have a similar problem. I started a thread about this but with the MX7000-BL5000 combination.
On the end, i wish to use my BL7000 for my MX7000, but my beolink has a lot of problems. (I buy it so.)
I think, thetwo way communication don't work from the BL side, maybe this is the known hardware problem with the capacitors in this Beolink. Don't know exactly, that my MX7000 is two way, it is type 33/86, SW 1.6
I have the Beosystem 2500 also here, it is for sure two way compatible, but my BL7000 don't see it. (No Contact)
So, after all this writeing, what i wish to know is, have I a real chance to let work the motorised stand with this TV and with this remote control?
Btw., the BL7000 is Type 1540, SW1.3
Thanks!
Charles
